Hey guys, i have an fx-6300 which is an AM3+ socket. I want to make my computer quieter and my cpu temps cooler. I am wonder what is a simple sub $100 liquid cooling solution would be if you guys have any recommendations? Thanks:)
 CPU: AMD FX-6300     COOLER: Hyper 212 EVO    MOBO: ASUS M5A97 R2.0    RAM: Team Vulcan 8Gb (4Gb x 2) , G-Skill Sniper (4Gb x 2)    PSU: Rosewill HIVE-750w    GPU: ASUS HD 7790 2Gb OC    CASE: NZXT Phantom 410    STORAGE: WD Black 1Tb , Intel 530 120Gb     AUDIO: HyperX Cloud , Sennheiser HD 518 , Audio Technica ATH-M30 , Sennheiser MM30G , Yamaha RX-V361 , Pioneer SP-BS22     PHONE: Samsung Galaxy S7 Edge     PERIPHERALS: Razer BlackWidow Ultimate Classic , Logitech g502 ( Thanks Syntaxvgm <3 )
https://linustechtips.com/topic/146144-fx-6300-liquid-cooling/
H100i (if you have the space) H90 if you have a 140mm fan mount, H80i if you can't fit either.
My System Specs: (Short list) i7 4770k, GTX 780, many SSD's, a 2 TB HDD(deceased :( ), Corsair 650D. Full list: http://pcpartpicker.com/user/kchriz6097/saved/8dh7YJ
Upgrade Plan: Acquire some Black Noctuas then add 16 or 32GB of 2133MHz memory
https://linustechtips.com/topic/146144-fx-6300-liquid-cooling/#findComment-1951550
save a buck. noctua fans on a hyper 212 evo
"If a Lobster is a fish because it moves by jumping, then a kangaroo is a bird" - Admiral Paulo de Castro Moreira da Silva
"There is nothing more difficult than fixing something that isn't all the way broken yet." - Author Unknown
Intel Core i7-3960X @ 4.6 GHz - Asus P9X79WS/IPMI - 12GB DDR3-1600 quad-channel - EVGA GTX 1080ti SC - Fractal Design Define R5 - 500GB Crucial MX200 - NH-D15 - Logitech G710+ - Mionix Naos 7000 - Sennheiser PC350 w/Topping VX-1
https://linustechtips.com/topic/146144-fx-6300-liquid-cooling/#findComment-1951587
i have the same CPU as you and i will have to agree with everyone else and say get a decent aircooler instead as your GPU isnt high end and the AIO coolers are worse then then aircoolers
 CPU: i5-6600k MOBO: ASUS Z170 Pro Gaming RAM: G.Skill 16GB 2800Mhz 15-15-15-35, GPU: Sapphire R9 290 SSD: Samsung 840 250GB HDD: Seagate Barracuda 2TB x2, Cooling: EK supremecy EVO ,EK-FC R9 290X with backplate, XSPC EX240 Crossflow & Alphacool UT60 240mm, XSPC D5 Bayres w/ Alphacool VPP655, 7/16-5/8 Compressions/Tubing, Noctua NF-F12 x4 PSU: Silverstone Strider Plus 850W Case: Nanoxia Deep Silence 1 http://valid.x86.fr/8g2m02
https://linustechtips.com/topic/146144-fx-6300-liquid-cooling/#findComment-1952722
You should get a better CPU before you think about getting a better cooling solution.
CPU: Intel Core i7 2600k | Mootherboard: ASUS P8z68v-Pro | GPU: EVGA GTX780Ti 3GB | RAM: Kingston HyperX Genesis 8GB (4GBx2) 1600mhz | PSU: Corsair AX760 | STORAGE: Samsung 840 Pro 512GB | COOLER: Noctua NH-C14 | CASE: Fractal Design Define R4 Pearl Black | Operating SystemWindows 7 Professional 64-bit |
https://linustechtips.com/topic/146144-fx-6300-liquid-cooling/#findComment-1954016
