Hello!
I am planning to custom cool (hard tube) my pc and am now researching a bit for for that purpose. Currently I have Noctua DH15 cooling my i7 12700KF and can say that the temps never go above 80 and as for the GPU I have an RTX 3090 OC version from Asus TuF.
Now all this is build inside the Fractal Design Meshify C.
If I go with water cooling would a combination of 240 and 360 rads manage to cool the GPU and CPU. (I am thinking to get the extra thin radiators from XSPC that measure only 20.5 mm.)
https://linustechtips.com/topic/1461351-cooling-planning/
9 hours ago, Prefelix said:
Hello!
Yeah, no problem. The GPU will benefit, the CPU will probably not chance so much. You can have a look at my builds in Meshify C if you want some ideas.
https://linustechtips.com/topic/1461351-cooling-planning/#findComment-15609066
