need a temporary internet solution
Go to solution Solved by Guest,
I'm assuming that your using a laptop. Just get a portable range extender. They have them that connect into USB.
Or, depending n your phone's provider, you can use it to connect your computer.
As they say, be aware, Data rates may apply.
currently renting a house while my new house is finalised but the wifi in the rental property is terrible past 2m away from the main hub, hoping to find some temporary solution like a mobile data kind of thing that i could use to have access to the internet throughout my home. also live in the uk so it needs to be something avaliable there
https://linustechtips.com/topic/1461303-need-a-temporary-internet-solution/
ill look into a range extender, thanks
