Hi everyone, so for about a month now I've had persistent stuttering in any game I play. The stuttering only appeared after I reset my PC, and at this point I feel like I've tried every solution I could find, even posting on Tom's Hardware before this聽Question - Games stuttering after reset | Tom's Hardware Forum (tomshardware.com). The main solutions I've tried to no avail were: Reinstalling my GPU drivers after using DDU, rolling back my GPU drivers, updating BIOS and chipsets, monitoring temps using afterburner, running sfc /scannow, culling my start-up programs and finally following this youtube guide that had me using Latencymon. It should also be mentioned that I tried updating to windows 11 which actually helped the issue somewhat although the stuttering is still very much there. In case it's needed I made a new benchmark as well聽MSI B450-A PRO MAX (MS-7B86) Performance Results - UserBenchmark, also the PSU is聽Bequiet! l11-cm-600w.
Needless to say, I would appreciate any and all help you guys are willing to provide 馃檪
I also captured this gameplay to hopefully shed some light on the issue.
Edited by Asper2988
Adding information
https://linustechtips.com/topic/1461273-persistent-stuttering-after-reset/
I鈥檝e seen heat issues without temps being visually high. 聽 The issue is temp probes only measure the places they are at. 聽There might be some part of the gpu that is over temp but has no probe. 聽My test for that is generally to give a machine way way more cold air than it should need and see if it changes anything. 聽I generally pull the side panel off and point a reallly powerful fan at it. 聽The one I got is for drying out area rugs. 聽It鈥檚 like 4500cfm. 聽 A box fan might do it though. 聽They鈥檙e also pretty big. Anyway, if that fixes it it鈥檚 a heat issue. 聽If it doesn鈥檛 it probably isn鈥檛.
another thing to look at is if you are cpu limited or gpu limited, and work from there. 聽The questions are when under load one of the two should be near 100%. 聽If neither is, do you have a zen2 cpu, and what is the MHz reading under load?
Edited by Bombastinator
Not a pro, not even very good. 聽I鈥檓 just old and have time currently. 聽Assuming I know a lot about computers can be a mistake.
The CPU is a R5 2600x, and the GPU a 1660ti, so I wouldn't think anything is being bottlenecked. As for the CPU it seems to boost up to 3.975 - 4.0 MHz. Adding to this the stuttering is present even in menus and stuff where the system isn't being stressed. I'll get back to you about the fan idea if I can find one in my house.聽
Everything bottlenecks. 聽Always. 聽The question is how much? 聽I鈥檝e got a pretty well balanced system for fallout 4. 聽4770k with garbage oc, and a 580. 聽I get 80% on the cpu with 100% on the cpu. 聽So I鈥檓 gpu capped on that machine, but not by much. 聽The whole fear of bottlenecking thing is stupid and doomed to failure anyway. You will always hit 100% cpu or 100% gpu. 聽The question is how big is the other when that limit is hit? 聽If you鈥檙e not hitting either though that signifies a problem. 聽The machine May supposed to be well balanced, but it also shouldn鈥檛 stutter which means something is up somewhere. 聽I鈥檓 just trying to find out where.
2 hours ago, Asper2988 said:
I tested out the fan trick, unfortunately it didn't seem to have any effect, so I don't think the GPU is throttling. The drops also seem to be present no matter how much I cap the frames and get worse if I leave them uncapped.
It does everything. 聽Cpu, gpu, VRM, etc.. 聽if you threw a lot off air in it though and nothing happend it鈥檚 likely something other than a heat issue though. 聽This is the problem with stuttering. 聽There鈥檚 just a ton of different things that might cause it and the only way to find it is just start whacking moles.
At least for FF14 it reaches 99% GPU at 40% CPU, so you might be on to something, if I'm reading afterburner correctly anyway. It's just strange because this issue only cropped up after resetting the PC...
I would go with RAM issue and checking if it is in dual mode. or as it is called nowadays 2x 64-bit聽
use CPU-Z for that.
xmp/DOCP enabled or disabled?
or a hard drive problem, go check your SMART聽
you have those stutterings in all of your games
btw do you got bf4, bf1, bf5?
Gigabyte X570 Aorus Elite,聽聽Ryzen 9 3900x, Dark Rock Pro 4, 16 GB聽Crucial Ballistix聽 RGB聽3600 MHz CL16 RAM, RTX 3080 TI FE Watercooled, 6 Case Fans,聽聽Fractal Design Meshify S2
You are awesome, stay safe and healthy.
use CPU-Z for that.
Unfortunately, I don't own those titles and it's getting late over here so I'll get back to you tomorrow when I've checked that stuff 馃檪
Could just be coincidence rather than causality
CpuZ is freeware. 聽So there鈥檚 that at least.
use CPU-Z for that.
Unfortunately, it seems like my RAM doesn't support XMP/DOCP, but it was running in dual channel. As for the storage, I'm using two SSDs in non-raid config that are about 2 years old. EDIT: Crystaldisk shows the drives as being in good condition.
Edited by Asper2988
Adding information
Well that鈥檚 odd. 聽What ram do you have what is it running at and what is it rated for?
Oh. 聽Remember it鈥檚 DDR RAM double data rate. 聽 1333x2 is 2666
Reset specifically? 聽I hate how Microsoft for gets it used a word already so it can mean 2 things. 聽There is the reset key which is like a reboot, and there is the reset where you reinstall windows but keep your data. 聽Not sure what the difference is between reset and refresh. 聽Probably is one though. 聽Reset may have changed a setting back to default. 聽Maybe look at those.聽
reset and in restart is different than the power button in that it forces a reboot instead of that obnoxious hybernation with toys thing Microsoft does. That could mean something too. 聽Tempted to try a refresh instead.
Ah sorry for not clarifying, I meant reset as in reinstalling windows.
Not your fault. 聽When one does that the windows OS is rewritten but not your data. 聽Perhaps something modified th OS ever so slightly when it got installed. 聽So what was rewritten wasn鈥檛 actually exactly the same as what was there earlier. 聽Is this just a games machine? Using software sites like steam?
Yeah it's mainly for gaming, and only has steam, spotify and discord on it.聽
Steam has a backup system. So that simplifies backups there. 聽Doesn鈥檛 make downloading a game any faster though. I don鈥檛 know much about Spotify or discord. 聽A clean install sounds possible. 聽Not particularly comfortable but possible.
Hi sorry for the late reply. After performing a full system format and reinstall of windows, the problem unfortunately still remains, and i don't really know what else to do at this point. My main take away would probably be that it could be hardware related if it still persists after all this.
