Power button
Go to solution Solved by Blue4130,
17 minutes ago, Airpenguin650 said:
Hi, I am trying to make an external power button for my pc to go on my desk, I really want to get this switch:https://www.amazon.co.uk/Heschen-Momentary-Emergency-Switch-Button/dp/B07LFWT4Q8/ref=sr_1_5?crid=2HLY2FS4HBR9H&keywords=Heschen+nc+stop+button&qid=1665699314&sprefix=heschen+nc+stop+button%2Caps%2C50&sr=8-5
however it is a normally closed switch when power buttons use normally open.
Is there any easy/cheap fix to this because I really like the look of the switch.
 Thanks
It will work both ways. Normally Open or closed depending on which of the 4 pins you use.
 Thanks
https://linustechtips.com/topic/1460886-power-button/
 Thanks
https://linustechtips.com/topic/1460886-power-button/#findComment-15605211
 Thanks
Screenshot 2022-10-14 at 05-39-32 Heschen Red Sign Momentary Emergency Stop Switch Push Button Switch 660V 10A with Box NC Amazon.co.uk DIY & Tools.png
Refresh before you reply
https://linustechtips.com/topic/1460886-power-button/#findComment-15605216
