Hello i need some help am building a PC to run and record minecraft for £150 (£50 for me profit so basically £100)its an order from a customer he doesn't care if parts are used or refurbished or whatever
so any ideas would be appreciated
I have a HDD and PSU so that doesn't count. I am thinking of an APU but not sure ...
https://linustechtips.com/topic/146053-cheapest-possible/
i don't want to know how that is even posible...
msi z97m gaming - i5 4690k @4.4ghz 1.2V corsair h110 powercolor r9 290x pcs+ - 8GB corsair vengeance dual channel @2133mhz - thermaltake smart power se 730watts - intel 530 series 240GB ssd seagate 1tb 7200rpm - corsiar obsidian 350D - 2x enermax tb silence 140mm - logitech x-530 - sony mdr xb600 - medion 24'' 1080P cm storm quickfire tk white edition with cherry mx red cheap but awesome mouse #GloriousPaintMasterRace
https://linustechtips.com/topic/146053-cheapest-possible/#findComment-1950229
... this would be the CHEPEST!!!! build, it would get 60ish fps on max graphics settings with about 8 chunks render with optifine installed:
CPU: AMD FX-4130 quad core ~$100
Motherboard: Gigabyte 78LMT-USB3  (accually decent enough on board graphics for minecraft) ~$60 on sale
Memory: cheapest 4gb single stick of ram ~$40
So $200 CAN or
~£109
*No case, Make one out of wood, getto FTW*
Wont record very well with that gpu, it would be ok with the render on about 6 chunks
My Car: http://linustechtips.com/main/topic/274320-the-long-awaited-car-thread/?p=4442206
CPU: i5 4590 |Motherboard: ASRock H97M PRO4|Memory: Corsair Vengance 8gbs|Storage: WD Caviar Blue 1TB|GPU: ZOTAC GTX 760 2gb|PSU: Thermaltech TR2 500W|Monitors: LG24M35 24" & Dual 19"|Mouse:Razer DeathAdder 2013 with SteelSeries Qck mini|Keyboard: Ducky DK2087 Zero MX Red|Headset: HyperX Cloud|Cooling: Corsair 120mm blue LED, Lepa vortex 120mm, stock 120mm|Case:Enermax Ostrog Blue Windowed
https://linustechtips.com/topic/146053-cheapest-possible/#findComment-1950276
AMD FX 4130 Black Edition £30
MSI 760GM-P23 FX AMD Socket AM3 Motherboard £30
Gainward GTX 260 Golden Sample Factory Overlooked £30
4gb 1600Mhz RAM - £23
£113
Well he has decided to put more money in 175 so 125 is my limit just case left to figure out
https://linustechtips.com/topic/146053-cheapest-possible/#findComment-1950394
As far as i know minecraft is not an gpu dependent game even  on an onboard gpu it would run just fine and i have done my research that the 4130 will do just fine
https://www.youtube.com/watch?v=ismOZoBALbQ
768p. Lol. I cosider 1080p the bare minimum these days.
https://linustechtips.com/topic/146053-cheapest-possible/#findComment-1950478
I higtly doubt that a 260 will do anything in therms of recording.
Not possible huh ? Are you sure ?  :rolleyes:
totally possible.... My craptop only get around 33 fps on mid settings, but most programs record at like 30 fps anyways
https://linustechtips.com/topic/146053-cheapest-possible/#findComment-1950567
<snip>
Correnct, a $35 gpu would be just fine for MC
"lol"? most laptops have that rez anyways
https://linustechtips.com/topic/146053-cheapest-possible/#findComment-1950573
