Unknow cable in case?
Go to solution Solved by Middcore,
It's for the case's USB-C port. It has to connect to the appropriate header on your motherboard, assuming there is one.
Corps aren't your friends. "Bottleneck calculators" are BS. Only suckers buy based on brand. It's your PC, do what makes you happy.  If your build meets your needs, you don't need anyone else to "rate" it for you. And talking about being part of a "master race" is cringe. Watch this space for further truths people need to hear.
https://linustechtips.com/topic/1460469-unknow-cable-in-case/#findComment-15601763
Ahhh ok, I thought it might have been that. Sadly I don’t think there is one because of my really old mobo but I’m not using it anyways. Thanks!
https://linustechtips.com/topic/1460469-unknow-cable-in-case/#findComment-15601779
