Xbox 1 cleaning
Go to solution Solved by BiotechBen,
Separate as many of the pieces as you can that have the wax on them, and then if you have a hair dryer: that will melt the wax off without getting hot enough to damage any components.
So I bought a pre-owned Xbox one and for the first 4years of owning it I haven't had any problems. Until recently it had started slowing down. So I decided to start with the easy cheap fix first, cleaning it. And upon tearing it down, I discovered that apparently someone had set a candle on the vents and there is candle wax all over the inside. I just want to find the safest way to clean it off without damaging the board.
https://linustechtips.com/topic/1460460-xbox-1-cleaning/
Thank you, I was hoping that would work. Just asked broadly to not limit the kind of answers I would receive.
https://linustechtips.com/topic/1460460-xbox-1-cleaning/#findComment-15601826
I would say that when doing that, whatever had the wax on it, put upside down so the wax drips off instead of running across the board.
https://linustechtips.com/topic/1460460-xbox-1-cleaning/#findComment-15602130
