Get 2 microfiber cloths. Damp one and wipe your screen when the TV is off, then use the other to wipe it dry. ONLY use microfiber cloth. Glossy glass screens can easily scratch otherwise.
If someone did not use reason to reach their conclusion in the first place, you cannot use reason to convince them otherwise.
https://linustechtips.com/topic/1460355-cleaning-an-oled-tv/#findComment-15601113
6 hours ago, MonkeyyWrench said:
And a appropriate cloth comes with this? Or do need to a get a micro fiber cloth as well?
https://linustechtips.com/topic/1460355-cleaning-an-oled-tv/#findComment-15601149
