cloning the drive
Asrock 890GX Extreme 3 - AMD Phenom II X4 955 @3.50GHz - Arctic Cooling Freezer XTREME Rev.2 - 4GB Kingston HyperX - AMD Radeon HD7850 - Kingston V300 240GB - Samsung Spinpoint F3 1TB - Chieftec APS-750 - Cooler Master HAF912 PLUS
osu! profile
https://linustechtips.com/topic/14591-please-help/#findComment-162075
If the SSD is big enough I think you can just make a robocopy, here is the batch file(I use this to back up my RAID0 (F) to my external HDD (E)):
@echo off
echo Backup
echo [1]Starten [2]Abbrechen
set /P a=
if "%a%" == 1 goto x1
if "%a%" == 2 goto x2
:x1
robocopy "F:" "E:" /MIR /XD "System Volume Information" /LOG:E:\copylog.txt /TEE /R:1 /W:1
pause
goto x2
:x2
echo Beende
Make SURE to use the correct drive letters, if you mix them up, your SSD will be copied to your HDD, leaving you with no data at all, so tripple check those!
AMD FX8320 @3.5ghz |  Gigabyte 990FXA-UD3  |  Corsair Vengeance 8gb 1600mhz  |  Hyper 412s  |  Gigabyte windforceR9 290  |  BeQuiet! 630w  |  Asus Xonar DGX  |  CoolerMast HAF 912+  |  Samsung 840 120gb
2 WD red 1tb RAID0  |  WD green 2tb(external, backup)  |  Asus VG278He  |  LG Flatron E2240  |  CMstorm Quickfire TK MXbrown  |  Sharkoon Fireglider  |  Audio Technica ATH700X
#KILLEDMYWIFE
https://linustechtips.com/topic/14591-please-help/#findComment-162078
