I have a problem with my laptop (HP ENVY x360 15-es1000ny) that whenever i turn on HDR it seems like my screen becomes so unsaturated.
The colours seem so blank with HDR turned on.
I also seem to be having a issue with a line (1px thick) running across my screen that is only there half the time? it disappears on black backgrounds.
And since updating windows 11 to 22H2 it seems like i cant connect a second monitor, it just doesn't detect it.
What could be the cause?
https://linustechtips.com/topic/1458534-hdr-seems-colourless/
idk, same with happens my aoc VA monitor.
https://linustechtips.com/topic/1458534-hdr-seems-colourless/#findComment-15588667
windows cant seem to find a HDR certification, yet offers to turn on HDR.
Attached are the screen specs
It doesn’t need a certification to have HDR, the base spec to call something HDR is absurdly low.
Maybe your display is just out of cal.
https://linustechtips.com/topic/1458534-hdr-seems-colourless/#findComment-15589417
Yet the problem doesn't persist with HDR turned off? Should i just forget about that feature on my laptop?
https://linustechtips.com/topic/1458534-hdr-seems-colourless/#findComment-15589744
Try watching some HDR content on the display first and then turn it off and watch it to see if it makes a difference
https://linustechtips.com/topic/1458534-hdr-seems-colourless/#findComment-15589851
