Fan controllers
Go to solution Solved by Cubit481,
Meh budget is not an issue.
then get the nzxt sen mix 2...or how about touch screen control... :)
http://www.newegg.com/Product/Product.aspx?Item=N82E16811992004
http://www.newegg.com/Product/Product.aspx?Item=N82E16811992005
I think this is the right spot to post this. If not will a Mod please move it.
 So i need a good fan controller. I have 6 fans, 3 hooked up to a controller that came with the case
( R4), but i have left out the other 3 because it was winter and was tooooooo loud. Now its 95 F and i need the other fans but want my computer quite for when i am not gaming. So, what is the best fan controller ( hardware or software ) i should get. I noticed in my  MOBO settings i can change it, but that takes far to much time to do that all the time, i need to be able to do it on the fly.
CPU  i7 6850k
GPU: EVA FTW3 3080
Monitor: Dell 2716DGR +  another 1440p ultra sharp.
SSD: 512GB 850 Pro | 970 Pro 500
AMP/DAC:Magni 3 + Modi  2.
Headphones: HD 6XX, Argons, HD 660S and like 9 more
https://linustechtips.com/topic/145794-fan-controllers/
I have this one, it is easy as to use/ install and it looks good: http://www.bitfenix.com/global/en/products/accessories/recon/
PC: Corsair C70 Arctic, FX 9370, Corsair H80i, Gigabyte 990fxa-ud3, Corsair Vengence 16gb, Palit JetStream GTX 970, OCZ Vertex 4 128gb and Western Digital Blue 1Tb + 500gb, Antec Gamer 520w
Peripherals: Logitech G19 and SteelSeries Sensei RAW
Toshiba L50-A: i7 4700mq, 8gb, 1TB HDD, GT 740M 2gb
https://linustechtips.com/topic/145794-fan-controllers/#findComment-1946660
This is the correct section.
Why not set an automatic fan curve with your motherboard utility?
https://linustechtips.com/topic/145794-fan-controllers/#findComment-1946663
That is a nice price too.
I honestly do not even know what this is. Ill do some research on it. I am assuming its easy.
CPU  i7 6850k
GPU: EVA FTW3 3080
https://linustechtips.com/topic/145794-fan-controllers/#findComment-1946669
If you can't do it through the bios, download the utility on the motherboard site.
https://linustechtips.com/topic/145794-fan-controllers/#findComment-1946675
what is ur budget...??
have a look on these... :)
http://www.newegg.com/Product/Product.aspx?Item=N82E16811992012
http://www.newegg.com/Product/Product.aspx?Item=N82E16811992007
and also u have like 4 fan headers on ur mobo...plug them on that and u can use fan xpert 2 utility to control them or switch them to automatic... :)
get the asus ai suite from here...
http://www.asus.com/Motherboards/MAXIMUS_VI_HERO/HelpDesk_Download/
https://linustechtips.com/topic/145794-fan-controllers/#findComment-1946716
CPU  i7 6850k
GPU: EVA FTW3 3080
https://linustechtips.com/topic/145794-fan-controllers/#findComment-1946765
Are all your fans PWM?
If not you only need 6 fans so there are loads of options, I think it's mostly up to personal preference http://www.scan.co.uk/search.aspx?q=%20%20%20%20Fan%20controller
CPU: i7 3770k@ 4.6Ghz@ 1.23v - GPU: Palit GTX 660ti - MOBO: Asrock Extreme 4 - RAM: Corsair vengeance 8GB 1600Mhz - PSU: OCZ 650watt - STORAGE: 128Gb corsair force GT SSD/ 1TB seagate barracuda 7200rpm
        COOLING: NH-U14s/ 3x Noiseblocker blacksilent pros/ Silverstone Air Penetrator/ 2 corsair AF120s
https://linustechtips.com/topic/145794-fan-controllers/#findComment-1946946
