easey case for building
Go to solution Solved by Alinz,
Kolink Citadel seems to be decent
TECWARE FORGE M2 BLACK & WHITE mATX MESH ARGB COMPACT GAMING
I don't know any of these cases or brands but from the pictures they look decent for thermals, hope this helps
Do you want to build a small formfactor pc?
Or do you just have a Mico ATX board already, because those fit in atx cases as well
My Rig: CPU : 10700K | RAM : Trident Z Neo 3600Mhz c16 32G (4x8) | CPU cooler : NHD15 | GPU : ASUS ProArt 4070 | PSU : Corsair RM850 (black label) | CASE : Corsair 5000D Airflow | Storage : Samsung 970 evo 1TB, WD Black 1TB, Samsung evo 850 Sata SSD | Casefans : Lian Li Unifan SL120 7X|
MOUSE : G Pro Wireless X superlight | Keyboard : Keychron C1- Pro-H1 Gateron Milky Reds
38 minutes ago, GOATWD said:
what case is easiesit to bulid in micro atx with hdd bays
The new Fractal Design Pop mini air should be really easy to work with https://www.fractal-design.com/products/cases/pop/pop-mini-air/RGB Orange Core/
Gaming PC:
CPU: Ryzen 5800X3D | Motherboard: Gigabyte B550 Elite V2 | RAM: Crucial 2x16gb, 3200  JEDEC. | PSU: EVGA SuperNova 750 G3 | Monitor: LG 27GL850-B , Samsung C27HG70 |
GPU: Asus Prime RTX 5070ti OC| Sound: Odac + Fiio E09K | Case: Fractal Design R6 TG Blackout |Storage: Kingston Renegade 2TB and Corsair MP510 960gb | Cooling: CPU: Alphacool ST30 420mm rad, Alphacool CPU and GPU Core LT and Core blocks, D5 pump and res combo
Linux PC:
CPU: Ryzen 7700| Motherboard: Asus A620M-CSM | RAM: Crucial Pro 2x48gb, 5600  JEDEC. | PSU: Corsair CX750 | Monitor: LG 27GL850-B , Samsung C27HG70 |
GPU: MSI Gaming X RTX 3090 | Case: Lian Li Dan Cases A3-mATX black |Storage: SN7100 2TB + Samsung 860 EVO 512gb | Cooling: CPU: Thermalright Peerless Assassin Mini Fan(s): Noctua 1x NF-A14x25 Chromax
How many hdds are you planning to use?
Your m-atx board will fit any atx case if that helps, so you have full choice over both m-atx cases and atx cases.
well i have 2 rn i just need space to work and rad soport if that helps
How many rads will you be running and what PSU will you buy/do you have?
HDD drive bays can interfere with psu cables, so a longer PSU can be hard to fit in some cases whilst maintaining 3,5 inch hdd bays.
That for instance is a problem with the 5000D, but I guess you could always just doublesided tape it in another place.
A Be Quiet! Pure Base 500DX might be a good option for you.
image.thumb.png.7ee6efc8e953b78f3365a78eaa1506cf.pngthat is what im geting
Sooo, no radiators as for now?
Also what is your budget?
I don't know any of these cases or brand but from the pictures they look decent for thermals, hope this helps
well thx u i see im going to get the 2nd case thx u
IMO, "easy to build in" isn't all that important. Most people will put their pc together, and maybe clean it out once a year. And most people don't even take their entire pc apart, to clean it. So "it doesn't matter" if you only plan to build your pc once. I would focus on how good it looks, if the airflow is good enough, and if I can fit all my parts. (in the reverse order btw)
well this is my first build and i will be opening it mounthly since im a mager germa aphobe
With that many drives, have you looked into a server case instead?
I am not aware that any have RGB built in. The last thing to worry about is looks because none of them are designed to be lookers, as they're usually behind walls and thus out of sight for onlookers.
