No Boot Device HELP!
Solved by NF-A12x25,
Either a drive has failed, or it’s come unplugged. Try plugging your hard drive or SSD back in.
If it’s failed, you’ll need to get a new drive and your files are toast. That’s why backing up your system is so important. But hopefully it’s just unplugged.
IAmAndre ·
Posted in New Builds and Planning1 -
8
2
Playgb2 ·
Posted in Troubleshooting1 -
1
1
5
1
kasdashd ·
4
play_circle_filled
Latest From ShortCircuit:
