Had some recent crashes so decided to test the ram (running Corsair Dominator Platinum kit) and as you can see from the memtest it is showing errors... just wondering though does this mean that there is a very good chance it is just my ram that is dodgy or that some other hardware could be causing the ram to fail?
10154031_10152104064556094_3522734126480
https://linustechtips.com/topic/145664-ram-problem/
How many tests did you do? Did they all come up the same?
GILBERNATA
"They will suck your energy from you -- the energy you call money and will put it to evil ends giving you worthless dross in return, Your inner self will protect you from this."
https://linustechtips.com/topic/145664-ram-problem/#findComment-1944981
I literally only ran the test for a minute so something was obviously weird, anyway I pulled a stick out and no errors, and so far with all of the ram re-seated no errors but will do a 12 hour test to confirm this.... if it was something as stupid as the ram being unseated then geez hahaha
https://linustechtips.com/topic/145664-ram-problem/#findComment-1945041
