Extra case fans: Corsair ML140 vs Noctua NF-A14 5V PWM
38 minutes ago, Queen Chrysalis said:Any case fan will get the job done about as good as any other, and none of them are loud anymore.
GamersNexus and Aris (HardwareBusters) disagree with that, with their new many thousands of euros Lonwgin testing machines xD. If Linus wants LAB32 to compete he's gonna have to get a Longwin as well.
@DJRWolfAt the best fan testing available so far here's how both of the fans did:
36 dBA at 250FPM for the Noctua (at around a bit more than 1000 RPM (pic below)
And about just under 35 dBA for the ML140 at the same 250 FPM (picture below)
They're very similar, so it comes down to your ears, which motor, you like more (especially at lower speeds). But do note that neither are that good noise wise at higher speeds (there's better options). Having said that, ~1000 RPM is like a sweet-spot, upper sweet spot for 140mm fans). So yeah, both are good options.
but the Corsair doesn't have the cleanest sound color/sound profile (they seem to have fixed it with the the Elite versions), so if u can find a Corsair ML140 LED Elite for similar price, I'd get the new ML Elite. Otherwise the Noctua.
