Just installed my ryzen 7 5800x upgrading from ryzen 3 3200 whenever I play games such as r6 specifically in ranked matches my pc completely crashes
my specs are
Ryzen 7 5800x
Gtx 1650
500w power supply
oloy 16 gig ram
gigabyte a320-s2h rev 1x
ID-COOLING SE-914-XT-Basic CPU Cooler 1
I think that it’s either the ram, mobo, or psu but I don’t wanna buy each one to test so idk what to do
https://linustechtips.com/topic/1455280-need-help-with-5800x-causing-crashes/
Any BSOD Messages? And have you updated the bios to the most recent version for your Mobo?
Marline
Top Loop:
Thermaltake Pacific PR2U Dual 5.25" Bay D5 Pump/Resorvior Combo / EK ZMT Tubing / A mixture of Chrome Plated Brass Rotary Fittings Bit Fenix and Alpha Cool / Alphacool NexXxos 280mm 45mm Thick Copper Pass-through Radiator / Alphacool NexXxos 140mm 45mm Thick Copper Radiator / XSPC G1/4 1/2ID Chrome Compression Fittings / Freeze Mod AM4 CPU Waterblock / 3x Noctua Redux 140mm fans
The Bottom:
Custom Made 2mm Thick Steel PSU Shroud / Aqua Computer Aqua Tube POM Reservoir / Alphacool Eisdeck 5 w/D5 655 Pump / EK ZMT Tubing / Alphacool 45° Chrome Plated Brass Rotary Fittings / Bitfenix 90° Chrome Plated Brass Rotary Fittings / Alphacool Chrome Plates Brass Pass Through Fittings / Koolance QD3 Quick Disconnects / Bitfenix Full Cover Water Block 2080ti / Alphacool NexXxos 200mm 45mm Thick Copper Radiator / Noctua Chromax 200mm Fan / The fluid I used for both was EK Cryofuel Acid Green
Computer Specs:
Thermaltake F31 Suppressor / Ryzen 9 3950X / 32gb G. Skill 3200mhz RAM / Asus B550-E motherboard / Zotac RTX 2080 ti 11gb / EVGA 1000 GS PSU / Samsung 970 Evo Gen3 NVMe SSD / Western Digital SN850X Gen 4 NVMe SSD / 4x PNY 120 gb SSDs in RAID 0 / 1x Spectre 512gb SSD / 1x Patriot 240gb SSD / 1x 1Tb Western Digital Black 7200RPM HDD / 1x 2Tb Seagate 5400RPM HDD / Windows 10
Your worst part is the mobo...
But it could be thermals did you check your temps?
What is this "$30 TD cpu cooler"?
That motherboard definitely doesn't seem 5800x suitable.
Ryzen 7 7800x3D -  Asus RTX4090 TUF OC- Asrock X670E Taichi - 32GB DDR5-6000CL30 - SuperFlower 1000W - Fractal Torrent - Assassin IV - 42" LG C2 - Windows 11 Pro
No blue screens and yes when I first put the cpu in it wouldn’t post so I had to flash the new bios then it posted
Yes I checked my temps and it is not overheating because I even put it to 6 cores and it ran at 40-50 c when gaming and still crashed
ID-COOLING SE-914-XT-Basic CPU Cooler 126mm Height CPU Air Cooler 4 Heatpipes CPU Air Cooler 92mm PWM Fan Air Cooling for Intel/AMD, LGA 1700 Compatible
the mobo says it can support it with the bios update that I flashed onto it
That CPU cooler is not adequate for a 5800x.
Im willing to bet that motherboard is struggling VRM wise under any heavy load. The fact that the BIOS update added support for Ryzen 5000 doesn’t meant it’s suitable for a higher power 5800x. 5600x would have been the most powerful chip I’d be comfortable putting in that board.
Can you temporarily point a fan at the VRM area? Then again with looking at temps I don’t know how that poor 92mm cooler is doing either.
HWINFO64 for monitoring temps. I’d be real curious what happens when starting a Cinebench test.
  • 2 weeks later...
When I run cinebench it does not crash but when I run a OCCT test it crashes instantly
So what do you suggest I do? Buy a new mobo and cpu cooler?
