Using LMR-400 as WiFi antenna extension
2 hours ago, Paddo said:AP1 is a AVM FritzBox 4040 (2.4GHz and 5GHz), AP2 is a TP-Link WR1043ND V1(2.4GHz only) running dd-wrt custom firmware. AP2 is aleady quiet high up(2.5m), I don't think putting it any higher up would do anything.
Running CAT7 from AP2 to the gaming room would be possible but won't do any good for now with the poor connection between AP1 and AP2.
What about the height of AP1, or changing its position? Can it be moved closer to AP2 at all?
I wonder if mixing two different chipsets (even though they're the same vendor) might be at issue here? Maybe things have moved on, but when I was using OpenWRT (or maybe I was on DD-WRT too back then, can't remember) in WDS mode the documentation said to only use it with identical hardware at both ends, as the implementation is not always standards compliant between different WiFi chipsets. I assume you're not using 802.11s as that is a completely different kind of mesh that is meant for making huge WiFi networks with resiliency rather than speed.
That said, have you tested AP1 and AP2 in the same room to see how fast they can achieve in ideal circumstances?
I wonder if upgrading to WiFi 6 might help? I had awful performance on 2.4Ghz for years, since it became so crowded (over really short range too) but it improved dramatically when I moved to WiFi 6. Its why it frustrates me to see so many vendors selling APs with WiFi 6 only on 5Ghz, as it makes a much bigger improvement to 2.4Ghz as that never got upgraded when WiFi 5 came out.
Also, don't bother with CAT7 if you do add another hard link, its not an official standard. CAT5e is enough for Gigabit, CAT6A if you want a little future proofing.
