Budget (including currency): 800 euro
Country: netherlands
Games, programs or workloads that it will be used for:  gaming and a bit of streaming
https://azerty.nl/sharecart/index/index/key/sf5sxm4EfdmzwqFue4xqlw0RisWqkYr6/ i want to get this pc i already have the gpu and ssd so i wanted to ask if there is anything i would need to change or not
https://linustechtips.com/topic/1454667-pc-upgrade/
what gpu are you using? if its a powerful one you might consider a different psu, maybe try for an EVGA 850BS or something like that.
i would also recommend the i5 K series cpus instead of the 12400 as they arent as good for price. the 12600K is so much more powerful and is much better than the 12400.
as far as the RAM goes there isnt any need for 32GB unless you play super demanding games or multitask lots. sometimes it can be handy, but 16GB is often enough to get by, and its a lot cheaper aswell as often faster speeds.
https://linustechtips.com/topic/1454667-pc-upgrade/#findComment-15561012
1 hour ago, Ryuikko said:
What's the gpu that you have already?
Looks ~fine, I'd want faster ram since 2666 is pretty slow and probably a better board as well.
Something like this
https://nl.pcpartpicker.com/list/mnKcNc
i have a 3060 ti  and ill look in to both suggestions
https://linustechtips.com/topic/1454667-pc-upgrade/#findComment-15561132
Something like this
so the pc is now 900 wich im ok with ive used both of ur suggestions with 2 tweaks 1 is i used the smae cooler as in the beginning because the one ryuikko said was as expensive on azerty as the one i chose and i went from corsair ram to gskill ram heres the new list https://azerty.nl/sharecart/index/index/key/jLU24may96M3YJwrQL55k1NmKlYhpjso/
https://linustechtips.com/topic/1454667-pc-upgrade/#findComment-15561156
