Budget (including currency):  2000-3000 Can$ Rather keep it on the lower end
Country: CAnada
Games, programs or workloads that it will be used for:  I love programming and devlopping some strage idea I have. So it will mainly be to create a game. From A to Z Sounds, 3D models, Engine.
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc):  The improved list : https://pcpartpicker.com/list/MRTQLs
Edit : Hello everyone,
         I am very happy that there is a community to help. Cant wait to hear your feedback.
          I really want the Wifi on the motherboard
https://linustechtips.com/topic/1453529-my-first-build-reviewed/
Have you already built this? Or seeking input before build? Being in Canada, you're kinda stuck with with you can get and the overall limited buying power, but I wonder if there are some bang-for-the-buck plays to be made here.
For starters, I wouldn't insist on wifi on the motherboard. These can be quite quirky and if they fail, you have a problem you don't want to think about... A cheap 1200mbps USB wifi adapter does fine.
Edited by An0maly_76
Revised, more info
I don't badmouth others' input, I'd appreciate others not badmouthing mine. *** More below ***
MODERATE TO SEVERE AUTISTIC, COMPLICATED WITH COVID FOG
Due to the above, I've likely revised posts <30 min old, and do not think as you do.
THINK BEFORE YOU REPLY!
2 hours ago, Coolmaster said:
Looks fine except that you're using a B660 motherboard with a 12700K, I would recommend getting a Z690 board.
Why?  There's literally no point with alder lake, as the lead cores will automatically boost to the max frequency, no games ever need them to go that fast, and having anything other than the lead core boosted to 5GHz never matter outside of saving a couple minutes on hour long video renders.
I edit the shit out of my posts.  Refresh before you respond.
Thank you, I will go with a z690 board with an adaptor
You made a good point, I forgot to say I love playing with virtual machines, so having more thread is kinda important. I was thinking going with the
Intel Core i7-12700 instead.
So it is looking like it will would be
CPU:  Intel Core i7-12700
CPU Cooler: DeepCool AK620 High-Performance CPU Cooler,
Motherboard: MSI PRO Z690-P DDR4 LGA 1700 Intel Z690 SATA 6Gb/s ATX Intel Motherboard
Memory: G.SKILL Ripjaws V Series 32GB (2 x 16GB) 288-Pin PC RAM DDR4 3200 (PC4 25600) Desktop Memory Model F4-3200C16D-32GVK
Storage: Samsung 970 Evo Plus 2 TB M.2-2280 NVME Solid State Drive
Video Card: EVGA GeForce RTX 3080 Ti XC3 ULTRA GAMING Video Card, 12G-P5-3955-KR, 12GB GDDR6X, iCX3 Cooling, ARGB LED, Metal Backplate
Case: Corsair 4000D Airflow ATX Mid Tower Case
Power Supply: Corsair RMx (2021) 850 W 80+ Gold Certified Fully Modular ATX Power Supply
I forgot to mention earlier, and it's not as big of a price differential in Canada as it is in the States, but with M.2s, you generally don't notice the speed increase much past 3,500 mbps. I usually recommend the WD Blue SN550 / SN570s here, but while $20 is $20, it's not that big of a price differential. Although that could offset the price of a USB wifi adapter. 😎
ADDED: I noticed your post states you are in Canada, however, your link is using the US version of PCPartPicker, which would be reliant on US pricing and availability. Unfortunately, in Canada, availability makes for a bit of a challenge. I am unsure if you have any preference to Intel over AMD, but here is my best bang-for-the-buck build based on Canadian sourcing and pricing.
https://ca.pcpartpicker.com/user/An0maly1976/saved/WW4QdC
Revised, more info
