I MESSED UP crucial P5 Plus 500 GB m.2 nvme cloning problems (SOLVED with step by step guide at the bottom of post)
image 1 - ladies and gentelmen i have solved my own issue. with 2 software and they are all free.
image 2 - i formated my solved drive to repeat the problem and to document to other so they can help them selves
image 3 select your drive then right click and inizilate disk.
image :
image:
note at this point you have 2 choices to download (or whatever) a clone software what i have used is :
O&O disk image 17 professioal trial
OR
Macrium Reflect
both are fine and easy to use
what i am going to use is Macrium reflect for this Totourial
image :
image :
image :
image :
image :
image :
image: skip to next
image :
image :
image :
image :
dont worry that where the other software will take care of.
MiniTool Partition Wizard free 12.6
image :
image :
image :
image :
image :
image :
image :
image :
image :
image :
this was painful to do step by step but i hope it helped someone in a similar situtaion like i was.
i would like to say i am not going to add details it painful and time consuming
alhamdurilah may you benefit from this post.
regards,
saif the arab
EDIT SORRY I FORGOT TO ADD ANOTHER STEP.
ON THE BOTTOM LEFT CORNER PLEASE CLICK APPLY AND ACCEPT I COMPLETELY FORGOT THOUGH IT WAS DONE BUT I FORGOT TO APPLY TO ACCEPT THAT ALL
