From the information from https://www.gigabyte.com/Motherboard/X570-AORUS-PRO-rev-10#kf
This motherboard only support HDMI and it is HDMI 2.0 and it support up to 4096x2160@60 Hz.
You shouldn't get 30hz. Sound weird.
Try update the motherboard bios to see any changes or not.
Also check your monitor menu to see whether got setting to choose HDMI 1.4 or 2.0
LG and Samsung do have this setting and you need to change it.
PC: AMD Ryzen 9 5900X, Gigabyte GeForce RTX 4090 OC 24G, X570 AORUS Elite WIFI Motherboard, HyperX FURY 32GB DDR4-3200 RGB RAM, Creative Sound Blaster AE-9 Sound Card, Samsung 970 Evo Plus M.2 SATA 500GB, ADATA XPG SX8200 Pro M.2 SATA 2TB, Asus HyperX Fury RGB SSD 960GB, Seagate Barracuda 7200RPM 3.5 HDD 2TB, Cooler Master MASTERLIQUID ML240R ARGB, Cooler Master MASTERFAN MF120R ARGB, Cooler Master ELV8 Graphics Card Holder ARGB, Asus ROG Strix 1000G PSU, Lian Li LANCOOL II MESH RGB Case, Windows 11 Pro (22H2).
Laptop: Asus Vivobook "A Bathing Ape" - ASUS Vivobook S 15 OLED BAPE Edition: Intel i9-13900H, 16 GB RAM, 15.6" 2.8K 120hz OLED | Apple MacBook Pro 14" 2023: M2 Pro, 16 GB RAM, NVMe 512 GB | Asus VivoBook 15 OLED: Intel® Core™ i3-1125G4, Intel UHD, 8 GB RAM, Micron NVMe 512 GB | Illegear Z5 SKYLAKE: Intel Core i7-6700HQ, Nvidia Geforce GTX 970M, 16 GB RAM, ADATA SU800 M.2 SATA 512GB.
Monitor: Samsung Odyssey OLED G9 49" 5120x1440 240hz QD-OLED HDR, LG OLED Flex 42LX3QPSA 41.5" 3840x2160 bendable 120hz WOLED, LG UltraGear Gaming Monitor 34" 34GN850 3440x1440 144hz (160hz OC) NanoIPS HDR, LG Ultrawide Gaming Monitor 34" 34UC79G 2560x1080 144hz IPS SDR, LG 24MK600 24" 1920x1080 75hz Freesync IPS SDR, BenQ EW2440ZH 24" 1920x1080 75hz VA SDR.
Input Device: Asus ROG Azoth Wireless Mechanical KeyboardAsus ROG Chakram X Origin Wireless MouseLogitech G913 Lightspeed Wireless RGB Mechanical Gaming Keyboard, Logitech G502X Wireless Mouse, Logitech G903 Lightspeed HERO Wireless Gaming Mouse, Logitech Pro X, Logitech MX Keys, Logitech MX Master 3, XBOX Wireless Controller Covert Forces Edition, Corsair K70 RAPIDFIRE Mechanical Gaming Keyboard, Corsair Dark Core RGB Pro SE Wireless Gaming Mouse, Logitech MK850 Wireless Keyboard & Mouse Combos.
Entertainment: LG 55" C9 OLED HDR Smart UHD TV with AI ThinQ®, 65" Samsung AU7000 4K UHD Smart TV, SONOS Beam (Gen 2) Dolby Atmos Soundbar, SONOS Sub Mini, SONOS Era 100 x2, SONOS Era 300 Dolby Atmos, Logitech G560 2.1 USB & Bluetooth Speaker, Logitech Z625 2.1 THX Speaker, Edifier M1370BT 2.1 Bluetooth Speaker, LG SK9Y 5.1.2 channel Dolby Atmos, Hi-Res Audio SoundBar, SONOS ACE, Technics AZ80, Technics A800E, Sony MDR-Z1R, Bang & Olufsen Beoplay EX, Sony WF-1000XM5, Sony WH-1000XM5, Sony WH-1000XM4, Apple AirPods MAX, Apple AirPods Pro 2, Samsung Galaxy Buds2, Nvidia Shield TV Pro (2019 edition), Apple TV 4K (2017 & 2021 Edition), Chromecast with Google TV, Sony UBP-X700 UltraHD Blu-ray, Panasonic DMP-UB400 UltraHD Blu-ray.
Mobile, Tablet & Smart Watch: Google Pixel 9 Pro XL (Obsidian) Apple iPhone 15 Pro Max (Natural Titanium), Apple iPad Pro 11" 2024 M4 (Space Black), Apple Watch Series 8 Stainless Steel with Milanese Loop (Graphite).
Others Gadgets: Asus SBW-06D2X-U Blu-ray RW Drive, 70 TB Ext. HDD, j5create JVCU100 USB HD Webcam with 360° rotation, ZTE UONU F620, Maxis Fibre WiFi 6 Router, Fantech MPR800 Soft Cloth RGB Gaming Mousepad, Fantech Headset Headphone Stand AC3001S RGB Lighting Base Tower, Infiniteracer RGB Gaming Chair
https://linustechtips.com/topic/1452869-aoc-3477-help/#findComment-15548692
Its the Aorus pro wifi v1.0 It has 2 hdmi and display port
Got the latest MB bios, needed that for the 5700g
https://linustechtips.com/topic/1452869-aoc-3477-help/#findComment-15548707
You should give a full name, earlier you said Aorus Pro X570 and Aorus Pro X570 and Aorus pro wifi is different. Also by telling Aorus pro wifi give many model with different chipset. The X570 AORUS PRO WIFI also don't see mentioned got DP and only 1x HDMI as well - https://www.gigabyte.com/Motherboard/X570-AORUS-PRO-WIFI-rev-10#kf
Also I cannot find your monitor, no monitor call AOC 3477, do have U3477.
A single missing wording can lead to wrong information as model name is very similar nowsday.
https://linustechtips.com/topic/1452869-aoc-3477-help/#findComment-15548714
21 minutes ago, Senzelian said:
This should show you how its done.
https://www.amd.com/de/support/kb/faq/dh-032
Haven't quite got the same things. Got the newer adrenaline software. allows custom res setting but stops me going to 60hz. Would the cable stop it attaining a higher refresh rate?
https://linustechtips.com/topic/1452869-aoc-3477-help/#findComment-15548737
Maybe? I'm not entirely sure if a cable could cause such an issue, but I wouldn't rule it out either. It's also the cheapest troubleshooting option, so why not give it a shot and get another cable?
https://linustechtips.com/topic/1452869-aoc-3477-help/#findComment-15548743
Just ordered one from amazon. Just missed out on next day delivery. Nice monitor though, ultrawide might take a bit of getting used to but having the extra space for my astrophoto editing will be nice,
https://linustechtips.com/topic/1452869-aoc-3477-help/#findComment-15548767
If your cable is older HDMI 1.4 then this will be the issue. Normally the monitor came with the cable and it will came with the latest version that monitor support. So the bundle HDMI 2.0 cable should do it fine.
https://linustechtips.com/topic/1452869-aoc-3477-help/#findComment-15548779
Its a used monitor. eBay bargain. Just grabbed a cable from the drawer. Is Display port or HDMI better?
https://linustechtips.com/topic/1452869-aoc-3477-help/#findComment-15548793
Cables do not have specifications in the sense that a port has a specification. All HDMI cables have the same amount of pins, but they're simply tested and rated for certain speeds. From my experience cables do either function at the correct frequency and resolution, or they start to flicker or not work at all.
That's why I'm not sure if a cable would even fix this issue, no matter what it is rated for. I haven't experienced a cable ever causing an issue where only lower resolutions or frequencies are available and I don't think it's expected behavior.
https://linustechtips.com/topic/1452869-aoc-3477-help/#findComment-15548834
Cable is making an important part same as the port. It do look same but the bandwidth is not same and cable do have specification. Well known brand cable did not simply test and simply rating. Off course those unknown very cheap cable might simply rate and not meet the suppose label requirement.
For example a HDMI version 1 4 cable definitely cannot fulfill the bandwidth requirement of HDMI 2.0 port.
https://linustechtips.com/topic/1452869-aoc-3477-help/#findComment-15548855
For 3440x1440 144hz normally required DP, also if future you are buying Nvidia GPU then only DP can give you G-sync support as HDMI only latest version 2.1 support G-sync. This also apply to AMD GPU Freesync.
It is better and safe to get the DP v1.4 even though your monitor only support up to v1.2 but v1.4 can be more future proof.
https://linustechtips.com/topic/1452869-aoc-3477-help/#findComment-15548861
And that is where you are wrong. It absolutely can. There are cables that weren't even around when modern HDMI specifications were created and yet they work just fine. Keep in mind cables are passive objects that do not decide anything. A controller behind an HDMI port on the other hand can artificially create a limit to a bandwith.
And this is exactly why I said that I do not know how a cable would impact the frequency in case of signal drop. I don't think it would simply cause a certain frequency to not show up anymore, as soon as a low quality cable is connected, as there wouldn't be any way for the display or the computer to tell that they are connected to a low quality cable. I would expect the signal to simply drop out and create a temporary black screen.
Quote
There are differences between various HDMI cables, but they are not classified by "HDMI version" because that would not be an accurate way of distinguishing the different cable types.
https://linustechtips.com/topic/1452869-aoc-3477-help/#findComment-15548953
Go use HDMI 1.4 cable and attached to 5120x1440 Samsung Odyssey Neo G9 monitor and try running it 120hz (I did not said 240hz as that only DP can do even though my monitor is equipped with HDMI 2.1) or any 4K  TV and running it as well 120hz see you can get it or not. The 120hz will not show up in your display control panel at all for you to choose.
Earlier no label as no standard is out and now it is label as version for easier understanding by consumer instead of label it as bandwidth. The bandwidth information is written at the description is far than enough.
https://linustechtips.com/topic/1452869-aoc-3477-help/#findComment-15549133
