Need help
Solved by Ryuikko,
No you won't be able to upgrade past 5th gen since that's the last gen of cpu that's on the (lga1150?) Socket
You could upgrade to a 3k series Card since pcie is backwards compatible, but you'd most likely be cpu bottlenecked
kerriya ·
Posted in Cases and Mods3 -
octester ·
Posted in Troubleshooting4 -
DavidPatrascu ·
Posted in General Discussion6 -
2
2
bill well ·
Posted in Peripherals1 -
4
2
Ha-Satan ·
Posted in Networking3 -
1
play_circle_filled
Latest From ShortCircuit:
