5800x temps
Go to solution Solved by Grimwolf94,
Through more research i found out its normal for the 5800x to run that hot. Apparently its the hottest running AMD CPU
14 minutes ago, Grimwolf94 said:
I recently built me a new pc a went to run it on cinabench. I am using a 240mm aio for cooling and temp jump to the high 80s withing a minute of all core test running. Is this normal?
my setup is a 5800x cpu 6800 gpu x570 motherboard 32gb of ddr4 ram the case is the 4000d airflow
have you oc any? what power management setting on windows?
MSI x399 sli plus  | AMD threardripper 2990wx all core 3ghz lock |Thermaltake flow ring 360 | EVGA 2080, Zotac 2080 |Gskill Ripjaws 128GB 3200 MHz | Corsair RM1200i |200tb raw | Asus tuff gaming mid tower| 10gb NIC
https://linustechtips.com/topic/1452104-5800x-temps/#findComment-15542819
