8700k 5ghz cache 4.71.32v delidded
h100i platinum cooler
hitting 80c on hottest core during aida64 and cinebench
aio liquid temp is 32c and fans set to 2000rpm
cpu used to max around 72c not sure why temps are so high now
Ambient is 25c
alternativly I can run 4.7ghz cache 4.3 at 1.2v and temps only hot 65c
15c difference seems a lot for .1v bump in voltage
something fishy going on or all seem normal ???
-14900kf
- 4000 32gb ram
-4070ti super duper
https://linustechtips.com/topic/1451696-cpu-hot-not-long-repasted/
2 hours ago, Guest 5150 said:
Before an answer, how about a question.
Which side of the IHS plate did you repaste?
Delid was done 5 years ago
repasted between cpu and cooler 1 year ago
-14900kf
- 4000 32gb ram
-4070ti super duper
If one core is significantly higher than the rest, It might be worth it to pop the top and replace the paste. It's takes the most abuse in that particular location.
Not like the temps you're getting are all that horrible, the core temp differences are suspicious though.
No but one core is a lot lower than the others, 80c on hottest and there rest are around 78/79 and then there one core at 72c highest
might be worth redelidding it ?
-14900kf
- 4000 32gb ram
-4070ti super duper
Well it's been 5 years.... usually one core is hotter, not 3 with one colder...
What pasted is used under and on top??
Liquid metal under 5 years ago and on top 1 year ago
-14900kf
- 4000 32gb ram
-4070ti super duper
4 hours ago, Guest 5150 said:
Not worth it if you used LM amd the plate hasn't been disturbed, not sure if it's replied glue or not.. but the cooler mounting pressure could just be the culprit.
Yeah was re glued
-14900kf
- 4000 32gb ram
-4070ti super duper
