Hello. I have just installed pfsense on hyper v. I have it setup like this.
ISP->ISP router->pfsense
I can access the lan on the isp router but i cant access the internet. The isp router is working fine, i know that. I have tried to change dns and so on. Does anyone know whart to do?
https://linustechtips.com/topic/1450192-problem-with-pfsense/
I'm going to assume that your ISP router is a router/modem combo?
If so, did you put it in bridge mode?
Desktop: AMD 9800x3d / Asus ROG Crosshair 870e Extreme / Asus ROG Astral 5090 OC / 32GB Corsair Titanium / 4TB & 2TB WD SN850x / Win 11 Pro
Plex/AI:  Intel Ultra 9 285k / Asus Tuf Gaming B860m-Plus / 2 x RTX 4000 ADA / 64GB Kingston Fury / 2 x 4TB Samsung 990 Pro / Win 11 Pro
NAS: Synology DS1821+ (8 x 20TB Seagate x24 ) / Synology RS1221+ (8 x 24TB Seagate x24) / Synology DS923+ (4 x 14TB Seagate)
https://linustechtips.com/topic/1450192-problem-with-pfsense/#findComment-15529635
Nope, it dosent have that function, i'm using a private ip from the isp router as the wan on pfsense. But the wierd thing is that i cat access the internet, just pfsense lan and the isp routers lan. And yes, i have unchecked the setting that blocks private networks.
https://linustechtips.com/topic/1450192-problem-with-pfsense/#findComment-15529637
What type of connection do you have?
Just trying to visualize your setup.
So it's ISP modem -> ISP router -> Hyper-V server with Pfsense in VM -> lan ?
https://linustechtips.com/topic/1450192-problem-with-pfsense/#findComment-15529639
Yes
ISP modem-->ISP router-->Server with pfsense in hyper v (on the isp's router's lan)-->pfSense lan.
https://linustechtips.com/topic/1450192-problem-with-pfsense/#findComment-15529640
Just now, Denniz said:
Yes
Why are you using the isp's router then?  You'd be double NATting.
Try: ISP modem to firewalled port on the pfsense nic, then the lan port to your switch/devices/ap (or however you are connecting your lan devices)
https://linustechtips.com/topic/1450192-problem-with-pfsense/#findComment-15529642
9 hours ago, Denniz said:
Yes
Can you get to the internet with a machine on the ISP router lan?
How are you connecting devices to pfsense if it’s virtualized?
https://linustechtips.com/topic/1450192-problem-with-pfsense/#findComment-15530071
