how about a corsair obsidian 350d-$109-micro_atx
http://www.corsair.com/us/pc-cases/obsidian-series-pc-case/obsidian-series-350d-windowed-micro-atx-pc-case.html
corsair GS600 80+bronze, 600watt-$100
http://www.corsair.com/us/power-supply-units/gs-series-power-supply-units/gs-series-gs600-80-plus-bronze-certified-power-supply-2013-edition.html
swiftech h220 liquid cooler(if you have any room left in budget)-$139
http://www.swiftech.com/H220.aspx
corsair vengence 8gb ram-$85
http://www.corsair.com/us/memory-by-product-family/vengeance/vengeance-8gb-dual-channel-ddr3-memory-kit-cmz8gx3m2x1600c8b.html
ASUS M5A78L motherboard-M-$60
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131795(sells it)
http://www.asus.com/us/Motherboards/M5A78LM_LX_PLUS/(full details/features and specs)
AMD FX-6350 Vishera 3.9GHz-$140
http://www.newegg.com/Product/Product.aspx?Item=N82E16819113327
Thermal paste-IC Diamond-$16
http://www.amazon.com/IC-Diamond-Carat-Thermal-Compound/dp/B0042IBAOG
prices could be lower elsewhere on the internet, i dont know all that much about gpu performances so i cannot recommend any
Energy can not be created nor destroyed, just converted to a different Type of energy.
My blog: T3Krant.blogspot.com
https://linustechtips.com/topic/14501-700-build-help-gaming-pc/#findComment-161004
I'd go fx6300 and a 7870XT (sapphire or club3d) as a base, get a cheap case like the Cooler Master K280, it's quite alright for the price :)
8gb of ram, just get something that's cheap (in Holland that is Kingston HyperX or GeIL black dragon).
If you have a hard drive lying around you could get an SSD instead. Otherwise choose storage, get 1TB or something ;)
That should make a nice base, nice balanced CPU/GPU if you ask me :)
i5 2500K - Asrock Extreme4 Gen3 - G.Skill RipjawsX 8GB- Asus GTX660 Ti - Crucial M4 256Gb
https://linustechtips.com/topic/14501-700-build-help-gaming-pc/#findComment-161310
Ive been told its better to spend on gpu rather than cpu so i would like to stick with the intel core i5 ive heard good reviews on the i5 in regards to gaming rigs
Then you'll spend more on CPU than GPU. For this amount of money for a build, its better to get an AMD cpu. Accept the truth.
https://linustechtips.com/topic/14501-700-build-help-gaming-pc/#findComment-161344
The i7 will not benefit in a gaming a rig as most games nowadays are GPU bound.
yea but i do allot of Photoshop and sony vegas 12 plus cinema 4d ect (everything in adobe master collection) so thats what i think the i7 helps allot but if your not doing that get the i5 for sure
https://linustechtips.com/topic/14501-700-build-help-gaming-pc/#findComment-164701
I umderstand but no i dont think ill be doing that i want the system to be purely gaming purposes
https://linustechtips.com/topic/14501-700-build-help-gaming-pc/#findComment-166740
Something like this should do the trick: $660 after taxes and fees,
http://gyazo.com/304f6bf217a3c5f4d3b2880c46a95bc4
This should be able to play all games adequately at high settings.
If you had another $100 to throw, you could get a samsung 840 120gb ssd to make it very snappy.
https://linustechtips.com/topic/14501-700-build-help-gaming-pc/#findComment-200935
