First PC build need help and tips
Solved by Ryuikko,
Nothing wrong with it per se, but you can make a better one like this
About what id reccommend
https://no.pcpartpicker.com/list/YzpWmr
The 12400f and 5600x perfrom pretty simairly with the 12400f edging the 5600 in single core workloads
Cheap cooler to keep the cpu cool
Good board for the price
Cheapest kit of 16gb ram
Good 1tb storage
3080 that's surprisingly cheap since it's a "premium" card, and will perfrom better than a 3070ti
Nice case and a good 850 watt psu
Edit* just saw you needed wifi/ monitor so adjusted list accordingly
