Help please
Solved by TetraSky,
Is everything plugged in properly?
Did the fans look like they were about to spin at all or just the RAM?
Is there still power in the wall outlet you're connected to ? (if the breaker jumped or not)
Did you try to boot the PC using a screwdriver and not the power button of the case? (unplug the front IO and manually short the two PWR Switch pins together using a screwdriver, pin 6 and 8)
Could you post pictures of the insides and entire back of the case so we can see what you did ? (high quality in good lighting and capture everything over multiple angles, not just select areas like so many tends to do, preferably... If you have a potato camera, forget I asked)
