Upgrading to RTX 3070 from GTX 980 Ti Please need suggest if i require PSU upgrade as well.
Solved by Ryuikko,
3 minutes ago, kinght2A4 said:any way what PSU do you recommend.
Any of the ones listed above are fine choices, but what do you plan to do with the pc? Some obvious changes and as mentioned above again, getting 2 individual sticks does not always guarantee operation and I'd look at getting a better mobo like the msi pro b660 a
