Budget (including currency): £300-340-350
Country: UK
Games, programs or workloads that it will be used for: genshin impact minecraft java/ bedrock, indie horror games, roblox and roblox studio, star trek online
current pc:
i7- 4770
16gb generic ram 2100mhz
gt 1030 ddr4
 i need reccomendations for motherboard and cpu inless you have an idea for a full pc. i DO NOT have a pc currently than i can upgrade or take parts from, the parts i have thought of so far for my budget pc build is a gtx 1650 and 16gb of ram, the cpu i have found but dont really want to use is ryzen 3 1200. i would like ideas for full pcs or help to continue this build. none of the parts ive said are final but there just what i found on my own
https://linustechtips.com/topic/1449379-need-budget-pc-help-read-description/
t that budget I would continue using the 4770 and just get the fastest GPU it can handle. I'd get an rx 6600 on ebay.  In the US they're going as low as $200, so in engerlund You should be able to pull one at a similar price.  There should be a lot of them on eBay as many people who bought one as a stopgap last winter are selling them with literally only a few months of usage.
What PSU is this system using?
I edit the shit out of my posts.  Refresh before you respond.
sorry for the late reply I cant take any of my parts from my old system as i am repurposing it as something else
