So I can<t find aywhere what number means what, you know on the impaact theres some led red number behind.
Have you checked in your motherboard's manual? It should say what everything means in there.
I like the color scheme of Noctua fans. Deal with it. Forget about the bad memories of the past.
"wunder you really are as straight as a rainbow" - Lanoi "can I fisterino your nose" - WunderWuffle
Forget about the bad memories of the past, take the good ones along with you through the present, and look forwards to the good things that will come in the future.
Yeah couldn't find it before posting... code ain't showing on manual but it's like altering, could it be showing the temps?
Is it only when you're booting your computer or is it constantly updating?
Check this .PDF file. http://dlcdnet.asus.com/pub/ASUS/mb/LGA1150/MAXIMUS-VI-IMPACT/E8469_Maximus_VI_Impact.pdf Section 1-25 through 1-30
Yeah I think it's the CPU temps.
