I was browsing on amazon then I stumbled across this https://www.amazon.com/gp/product/B09TV3DQZB/ref=ewc_pr_img_2?smid=ATVPDKIKX0DER&psc=1
I was looking for a pc with a 12th generation i5 and that was prebuilt, but the question is should I buy it, is it worth it and is it reliable?
https://linustechtips.com/topic/1448853-pre-built-pc/
it's out of stock and costs a grand for a 3050, not recommended.
PERIPHERY
- Table : IKEA Karbly 8FT counter top (brown) w/ 2 ALEX black drawers & OLOV LEG
- Chair : Herman Miller Aeron Remastered Ergonomic Chair
- Mouse 1 : Logitech Superlight X 2 (Black) (Using Now)
- Mouse 2 : Razer Viper V2 Pro (Black)
- Keyboard 1 : Logitech G413 SE Brown switches Lubed
- Keyboard 2 : Ducky One 2 SF Black CherryMX Silver Switches
- Monitor 1 : Benq Zowie XL2566K 360HZ 0.5MS
- Monitor 2 : ASUS PG279QE 1440p 165HZ
- Mousepad 1 : The Glorious 3XL Extended Mousepad (Black)
- Mousepad 2 : Benq G-Sr Speed Mousepad (Black)
- Mouse-Bungee : Razer Bungee V2 (only when wired)
- Headset : Beyerdynamic DT990 PRO 250 OHM grey/black
- Microphone : Shure MV7 XLR
- Mixer : TC-Helicon GOXLR
- Camera : Nikon 250D W/ Elgato CAMLINK 4K
- WebCam 1 : Logitech Brio 4K
- Webcam 2 : Logitech C922 1080p
- Controller : PS5 Controller Whiteout Edition
PC
- CPU : Intel I7 12700KF
- CPU-Cooler : NZXT Kraken X62
- GPU : Zotac Gaming GeForce RTX 3070 Ti Trinity OC 8G
- Motherboard : MSI MAG Z690 WIFI
- RAM : Corsair Vengeance Pro RGB 64GB
- Case : NZXT H700I Black/Red matte
- HDD : 2x 6TB (12TB) Seagate Exos 7E10 12GB/s
- SSD : 1TB Crucial P1 NVME M.2
- PSU : Corsair RM1000X (1000W Plus Gold) (W/ Red Sleeved Premium Corsair Cable kit)
https://linustechtips.com/topic/1448853-pre-built-pc/#findComment-15520124
Zotac is a known brand (it's mainly known for GPUs), but as for reliability... I honestly don't think you'll find the answer here, since it's doubtful folks own any Zotac PCs here, let alone that exact configuration.
The worth of the system? It's okay. The RTX 3050 is the lowest-end modern NVIDIA GPU you'll find, but that still makes it decent for most modern games. The 16GB of RAM will be fine, too. I'd mainly be concerned about the 500GB SSD; that's really not a lot of room if you're going to use it to store games or media. And like Fl0yd suggested, $1,100 is a lot to pay for a Windows machine like that.
Some extra details might help. What's your budget? What apps and games must run well?
https://linustechtips.com/topic/1448853-pre-built-pc/#findComment-15520129
1000$ but I am willing to stretch it out to 1100$ I will mostly be playing roblox and minecraft also recording both, maybe streaming movies and lite video editing, and if this pc isn't for me then can you recommend some other prebuilds?
https://linustechtips.com/topic/1448853-pre-built-pc/#findComment-15520168
That computer will definitely be up to the job, although you may want a secondary conventional hard drive to store videos.
As for recommendations: Zotac's pricing is better than it looked at first blush. But if you're wanting alternatives, I'd suggest looking at some MSI systems like the Codex R and MPG Trident 3. You might also want to look at computers with RTX 2060 graphics, as those might help you save a bit of money given your needs.
https://linustechtips.com/topic/1448853-pre-built-pc/#findComment-15520301
link?
https://linustechtips.com/topic/1448853-pre-built-pc/#findComment-15520328
it's just the concerning thing is that there is only 1 review and that is a 1 star review so I don't want to buy a bad pc and I can't find videos about it anywhere
https://linustechtips.com/topic/1448853-pre-built-pc/#findComment-15520801
