my phone which has 5.5A uses around that much per night, it it what it is.
Edit> why dont you vharge it overnight?
I Use my knowledge as business owner and self taught technician aswell as an AI to help people. AI might be controversial but it actually works pretty well 90% of the time.
https://linustechtips.com/topic/1448639-pixel-6a-battery-drain/#findComment-15518382
Because it still is running all the internet, checks your email, SMS and facebook etc. Bluetooth still searches for devices etc. You probably can disable some of that, though.
Most people plug it in over night, so this really isn't an issue. And you didn't define night. 4 hours? 8 hours? 12 hours? You also could have faulty apps that use CPU. Remove whatever apps you don't really need.
I don't know the 6a, but my 6Pro has 10x more powerful (based on range) Bluetooth, and Wifi than my previous phone. This is really nice, but it comes at the cost of power.
And the % likely doesn't mean anything. Same way a car showing half tank, doesn't mean exactly half. Going from 100% to 90% most likely is a different amount of energy than from 30% to 20%. This % is just based on voltage and maybe some algorithm added to ESTIMATE available energy. In addition the battery may not provide all capacity. 100% of nominal capacity could be only 90% of actual capacity. The manufacturer shows you whatever they want to show you.
Whenever I'm near a power source (wireless on all my desk, or plug by my bed, or in my car) I just re-charge. Never need to worry.
No signature
https://linustechtips.com/topic/1448639-pixel-6a-battery-drain/#findComment-15519674
Usage doesn't sound like a problem. Mine uses 40% overnight when going to sleep to waking up, problem here seems that it varies so much. Mine is 40% every night. The difference between 10 and 20 percent is huge. Maybe just early days of while your phone "learns" how to manage itself as many people say new Pixels do, that "it's normal."
MAIN: Ryzen 7 5800X3D - Kraken X62 Rev 2 - STRIX X470-I - 3600MHz 32GB Kingston Fury - 250GB 970 Evo boot - 2x 500GB 860 Evo - 1TB P3 - 4TB HDD - RX6800 - Antec HCG Platinum - Manta - Silent Wings Pro 4's enjoyer
SetupZowie XL2740 27.0" 240hz - Roccat Burt Pro OG Corsair K70 browns - PC38X - Mackie CR5X's Mackie CR8S-XBT
Current build on PCPartPicker
HTPC: Ryzen 7 2700X - BeQuiet! Shadow Rock 3 - STRIX X570-F - 3200MHz 32GB Corsair Dominator - 250GB Exceria boot - 500GB SN730 - 1TB Sandisk 3D - 4TB HDD - Limited Edition Vega 64 - Corsair RM750x 80+ Gold - North - Alphacool Apex Stealth Metal - BeQuiet! Light Wings
SetupHisense 55E7NQ - Hisense HS205G
HTPC on PCPartPicker
https://linustechtips.com/topic/1448639-pixel-6a-battery-drain/#findComment-15519727
