playing on ultra on btf4 and my gpu wont reach 100% nor is my cpu reaching 100% I highly doubt it's being bottlenecked as my cpu isn't reaching 100%
average fps is around 65 at 60-70% load on gpu and cpu.
My Little Gaming Rig:
CPU: FX 8320 | MOBO: Gigabyte 970A-D3P | RAM: G.Skill Ares 2x4GB | GPU: Sapphire Dual-X R9 270X | Storage: Seagate SSHD 1TB | Case: Corsair 200R | PSU: CM 550W V-Series
Upgrades to come: CPU FAN: Corsair H100i | RAM: 2 more 4GB sticks | GPU: Another R9 270X running in crossfire | Storage: Samsung 120GB SSD | PSU: Corsair 800w
https://linustechtips.com/topic/144824-gpu-not-using-100/
@WyvernAbstracts
From what I hear, BF4 isn't well optimised for PC. I imagine that because of this, obviously hardware isn't being fully utlilised.
Corsair 400R, i7 3770K @ 4.5GHz 16GB, Corsair Vengeance 1600MHz, Gigabyte Z77X-UD5H Motherboard, 240GB Samsung 840 Evo Sata III SSD, 2 x Asus GTX 780 Direct CU2 SLI, Corsair H100i and Corsair AX860i Platinum Power supply.
https://linustechtips.com/topic/144824-gpu-not-using-100/#findComment-1934037
@WyvernAbstracts
but when i watched jayz's video on bottlenecking he was reaching 100%, but he was playing on btf3. Is it just the game? I'm reaching playable fps anywho so i shouldn't be two worried.
https://linustechtips.com/topic/144824-gpu-not-using-100/#findComment-1934068
Driver issue.
using latest mantle driver, should be optimized for btf
https://linustechtips.com/topic/144824-gpu-not-using-100/#findComment-1934071
@WyvernAbstracts
I thought Mantle was supposed to utilize more hardware juice? What happened to that, or is that not what Mantle does? Sounds strange.
https://linustechtips.com/topic/144824-gpu-not-using-100/#findComment-1934080
My money is on the game optimisation. There is so much the GPU drivers can do to optimised and most performance is affected by the game itself. I hear nothing but bugs and issues with BF4 since it launch. I guess given time it will improve (maybe) AMD cards will work best with the game but tbh I doubt it will be even at the acceptable standard. Dice are just useless
https://linustechtips.com/topic/144824-gpu-not-using-100/#findComment-1934093
Yeah mantle was suppose to. There was so much hype about it, but unfortunately, it failed. In fact, it caused discolour in games and made things look unusual. Maybe they have fixed it now (i don't know). Mantle isn't much good in the current state
https://linustechtips.com/topic/144824-gpu-not-using-100/#findComment-1934117
my system runs bf4 buttery smooth at ultra in multiplayer and I use mantle (fx 8320 and r9 290)
1.update drivers to 14.4
2.use mantle if you aren't already
3.probably could raise you graphics settings since your at 65 fps and at 60-70% usage
disable core parking maybe
https://linustechtips.com/topic/144824-gpu-not-using-100/#findComment-1934146
mine runs it smoothly at 70 avg fps but is you gpu load at 100%?also im at ultra so how could i?
https://linustechtips.com/topic/144824-gpu-not-using-100/#findComment-1934187
Honestly I feel like it's partly due to drivers, but mainly due to Battlefield 4 being poorly optimized.
The game should get better over time. The only thing you can do is keep your drivers updated, and let dIce work their game out.
My Rig:
Case: NZXT H210 CPU: AMD Ryzen 7 3700x  Motherboard:  MSI B450 AM4 Motherboard  Memory: GeIL EVO POTENZA 16GB Video Card: MSI RX480 Power Supply: Corsair TX 750w Storage: Samsung 840 120GB And a 500GB WD BLUE Monitor: Acer S231HLbid 23" and an old Dell Mouse: RAZER DeathAdder 3.5G Keyboard: Ducky DK9008G2 PRO MX Cherry Blue
https://linustechtips.com/topic/144824-gpu-not-using-100/#findComment-1934212
The guys over at pcper said something similar but what they conclude is that with mantle plus cfx and amd's new drivers they don't go for crazy fps but try to work on frame times and consistency to lower tearing and such. would you say that when you play its butter smooth?
Loves PC Games :D
https://linustechtips.com/topic/144824-gpu-not-using-100/#findComment-1934587
butter smooth, till my internet's like na f@#k dis shit.
https://linustechtips.com/topic/144824-gpu-not-using-100/#findComment-1934623
