https://linustechtips.com/topic/1447964-need-help-choosing-an-ssd/
You dont need a 980 Pro as its way overkill, Gen 4 SSD's are still pretty much not utilized well on PC unless you are doing MASSIVE file size transfers. DirectStorage is still years away. A decent quality NVME 3.0 SSD will do fine. Generally Samsung 970 Evo, or a Crucial p2 one should be good.
10 minutes ago, davec4 said:
They are all pretty decent. You may want to check pricing on the SN770. Competitive with the SN850 and usually a bit less expensive.
None of them. Get a WD Blue SN570 and call it a day. Anything faster is a waste of money for at least one more generation of processor, maybe two. Food for thought, I exchanged that exact WD Black for the M.2 I recommend and it serves my 5900X / RTX3060ti just fine. Scores better than expected on CB R23 too.
Edited by An0maly_76
Revised, more info
I don't badmouth others' input, I'd appreciate others not badmouthing mine. *** More below ***
MODERATE TO SEVERE AUTISTIC, COMPLICATED WITH COVID FOG
Due to the above, I've likely revised posts <30 min old, and do not think as you do.
THINK BEFORE YOU REPLY!
