What are you planning to put in it?
https://linustechtips.com/topic/144729-small-m-atx-cases/#findComment-1932742
Corsair 200r/300r and the Coolermaster Silencio 550 are pretty clean cases. They support ATX and below (future mainboard options), come in at good price-points as well.
Social Links: LTT Forum    Website    Instagram    Twitter    YouTube    LinkedIn    Steam
The Build
CPU Intel i7 4770k 4.4ghz Motherboard Asus Sabertooth Z87 RAM 34gb (4 x 8gb) Corsair Vengeance 1600mhz GPU Evga GTX780 Classified Case Lian Li O11 Dynamic Storage Samsung 840 256gb SSD PSU Corsair HX750 Display Achieva Shimian QH300-IPSMS 1600p Cooling Corsair H100i Keyboard Corsair K90 Mouse Corsair M65 Sound 3.1 Surround Sound Fans 2x Corsair SP120 PWM, 3x Corsair AF140 Q.E, and 1x Corsair AF120 Q.E.
https://linustechtips.com/topic/144729-small-m-atx-cases/#findComment-1932749
I recommend the coolermaster n200 over the core 1000, its a lot easier to build in and it has more fans and bigger fans, cable routing is superior, bottem mounted psu as well.
The zalman T4(and T3, they are the same case but with slightly different exteriors) isnt the best case but its bloody cheap and some people like that, both cases have superior cooling then the c1000.
Lastly the aerocool deep silence, its much more expensive then the other cases but its smaller and for some reason smaller cases cost a lot but then again it is by far aerocools best case.
Listen if you care.
https://linustechtips.com/topic/144729-small-m-atx-cases/#findComment-1932757
the Prodigy M looks pretty small for an mATX case
Christian and Proud of it
Please read the CoC        My Build Log
https://linustechtips.com/topic/144729-small-m-atx-cases/#findComment-1932779
I would go for the N200
CPU: AMD Ryzen 7 3700X - CPU Cooler: Deepcool Castle 240EX - Motherboard: MSI B450 GAMING PRO CARBON AC
RAM: 2 x 8GB Corsair Vengeance Pro RBG 3200MHz - GPU: MSI RTX 3080 GAMING X TRIO
https://linustechtips.com/topic/144729-small-m-atx-cases/#findComment-1932964
