How to assign applications to specific network adapter.
SonOfaLag
I currently have satellite internet at my house.
I use Parsec to connect to my gaming pc (located in a different room) from my laptop (my house has ethernet plugs in every room) to play offline games.
I wanna play online games (via mobile hotspot from an old cell phone) but the issue is this:
I don't have enough bandwith on the phone's hotspot to directly use Parsec so I am forced to use Parsec via ethernet to stream the game.
So I was wondering if there was a way to force only Parsec to use ethernet connection make everything else go thru the mobile hotspot wifi.
You can use an application like ForceBindIP or create a VM and install Parsec on it and assign the nic you want to that vm
Desktop: Intel i7-13700K / Asus ROG Strix  z690-e / Nvidia 4080 FE / 32GB DDR5 Corsair Dominator / 2TB  WD SN850x  / 48" Lg C2 & 27" Asus ProArt
Plex Server: Dell OptiPlex 7010 /  i7-13700 /  32GB DDR5 / 1TB Samsung  990 Pro / Ubuntu
Laptop: M2 Macbook Air / 8G ram / 8core CPU / 10core GPU / 512GB SSD
NAS: Synology 1821+ , 2x Synology RS819 = 200TB
