prebuilt system with arc a310
4 minutes ago, WereCat said:Because there are big talks about Intel wanting to abandon Arc so you may not see any future drivers. The current state of drivers is so bad that even if they don't abandon it it will take months if not years to get it to a state where people can actually use it for systems they use daily and the performance is "fine" in some very minor cases, in most other applications the performance is significantly worse.
But since you made up your mind, there is no point trying to help you. We just wanted to warn you about the issues.
You think you may like to tinker with it but you will find out it to be just a waste of time and money in the end. But do as you like.
fine ima make a topic so we all can talk bout what hardware I can get for same money
