Pump bearing
Go to solution Solved by LIGISTX,
3 minutes ago, Tyler09 said:
I was making sure that my bearing fit in the pump of my new water cooled pc, but now it won’t come off, please help
Water Cooling Pump, 800L/H PC Water Cooling Integrated Mute Water Pump Support PWM for CPU Cooling System
XSPC bearings
I am confused. What is the issue in this picture?
XSPC bearings
https://linustechtips.com/topic/1446931-pump-bearing/#findComment-15505662
1 minute ago, Tyler09 said:
The bearing won’t come off
What bearing?
https://linustechtips.com/topic/1446931-pump-bearing/#findComment-15505665
Do you mean the fitting?
If you mean the fitting, do you need it to come off anyways? Your going to need to put the fittings in before you mount the block anyways, although a straight fitting pointing directly down like that, it may be very difficult to route tubing like that. Usually someone would use an elbow of sorts.
But, there is no reason it wouldn't come off, just have to twist it opposite way it went on. If you really forced it (which you don't need to do...), may need to use a vice grip or pliers to get a better grip on it and twist it off.
https://linustechtips.com/topic/1446931-pump-bearing/#findComment-15505674
Ok thank you, this is my first build
https://linustechtips.com/topic/1446931-pump-bearing/#findComment-15505725
Oh, that’s the pump bit the block. My comment about an elbow is less relevant, just depends where you place the pump.
But info about how to get it off/just leave it on is the same.
https://linustechtips.com/topic/1446931-pump-bearing/#findComment-15505731
