Peace of mind 5800x temps and R23 Score (Sorry)
10 minutes ago, coneil3822 said:I'm sorry to be a pain as you probably get load of these posts everyday.
You'd be right!
10 minutes ago, coneil3822 said:In Cinebench R23 Multi Core I'm getting a score of 15588 with 80 Degree temps, shouldn't it be a little cooler as I've got a 360mm?
Completely normal. 5800x gets hotter than you'd expect based on its physical design. Nearly 15600 is exactly where you want to be and 80c is nothing.
Robert Hallock - Director of Technical Marketing AMD:
QuoteYes. I want to be clear with everyone that AMD views temps up to 90C (5800X/5900X/5950X) and 95C (5600X) as typical and by design for full load conditions. Having a higher maximum temperature supported by the silicon and firmware allows the CPU to pursue higher and longer boost performance before the algorithm pulls back for thermal reasons.
Is it the same as Zen 2 or our competitor? No. But that doesn't mean something is "wrong." These parts are running exactly as-designed, producing the performance results we intend.
