General question about rgb
Solved by Birblover12,
If you leave it flashing for weeks on end you might fry a led or two, but you'll likely get a horrible headache before that even happens.
All jokes aside, you should be fine making your leds flash quickly, as long as they're from a reputable manufacturer then you'll be fine.
MadManMarsBar ·
Posted in Build Logs0 -
IAmAndre ·
Posted in New Builds and Planning3 -
4
2
Playgb2 ·
Posted in Troubleshooting1 -
2
1
5
1
play_circle_filled
Latest From ShortCircuit:
