I am in the market for a powerful gaming/productivity pc.
I have little experience in pc building.
Could someone recommend me a list
Budget (including currency): $1500
Country: USA
Games, programs or workloads that it will be used for: Forza Horizon 5 1440p, Apex Legends 1440p, Valorant 1440p, Blender, Premier Pro, School Work,
Thanks
https://linustechtips.com/topic/1445905-i-want-help/
Order a pre-build from a reputable source. Easiest way to obtain a decent gaming rig w/o having to scour the interweb for parts et all. As you lack experience, open the case and see how they've done the job: what parts they choose, how they mounted stuff, etc. Great learning tool, actually, besides being a functional gaming PC 😉
"You don't need eyes to see, you need vision"
(Faithless, 'Reverence' from the 1996 Reverence album)
https://linustechtips.com/topic/1445905-i-want-help/#findComment-15498813
I know HOW to build a pc, I just have never done it. THough, i want to get in the hobby of pc building
https://linustechtips.com/topic/1445905-i-want-help/#findComment-15498817
OK, I see. Well, head over to the pcpartpicker website and start playing with components until you find a combo that suits your budget and other requirements. Order the parts, wait however long for it to arrive and follow the LTT PC build guide published earlier this year. It was made with people like you in mind, so pretty educational.
https://linustechtips.com/topic/1445905-i-want-help/#findComment-15498827
Who hurt you....
https://linustechtips.com/topic/1445905-i-want-help/#findComment-15498831
On 7/27/2022 at 5:32 PM, Bhameck said:
https://pcpartpicker.com/list/dx96pH
At this price point, you can get solid performance, or solid aesthetics. Not really both. Personally, I think that performance is more important, so that is what I optimized this list for.
Thanks. this list is really helpful. I'll try to tweak this list for my likings
https://linustechtips.com/topic/1445905-i-want-help/#findComment-15500502
Also I made this list, how is it?
https://pcpartpicker.com/list/7GchFg
https://linustechtips.com/topic/1445905-i-want-help/#findComment-15500523
How's this list
https://linustechtips.com/topic/1445905-i-want-help/#findComment-15500526
Looks fine to me. Keep in mind the warning stated on that page about BIOS compatibility of the CPU.
Your budget allows some expansion:
1) upgrade the NVMe drive to a 1TB model, they're only slightly more expensive (around 110-120 USD) for twice the capacity
2) add a HDD for storage: personal files, games, video, etc. A 4 or even 8TB model should fit in your remaining budget
Good luck and enjoy building it!
https://linustechtips.com/topic/1445905-i-want-help/#findComment-15500668
7 hours ago, Ryuikko said:
I'd get the 12700f and b660  instead. Beats it pretty handily in every aspect
I made this list based on your recommendations:
I just need final thoughts before I buyvthe parts
https://pcpartpicker.com/list/WHDGbK
Again I have a all white theme
https://linustechtips.com/topic/1445905-i-want-help/#findComment-15501008
