Im thinking of upgrading my existing setup with a 3080 but should I upgrade something with it (can I do it gradually) (specs attached as image)
Budget: 1.400$ (10.000kr) or 1.800$ (13.000kr) at the absolute limit
Currency: Danish krone
Peripherals:
Mouse: Rival 650
Keyboard: Apex M400
Headset: Arctis 9
Monitor: right now its a simple 1080 p 120 hrs ( I am think about getting a 160 hrz
Games: Some VR titels like Boneworks,
B & S, Half Life. I also play som PC games including ARK for the most part (there are others but its a mixed bag) (discord is also going to be used
I'm doing an upgrade becus my setup right now is lacking behind in most big titels, and now I want one that right above the medium. If needed I'm almost willing to "build a new one" just with the old case, RAM and SSD.
Thanks in advance 🙂
https://linustechtips.com/topic/1445314-help-with-deciding-upgrade/
3 minutes ago, Ryuikko said:
I'm not entirely sure but the 9400f is still most likely enough to run a 3080 without any noticeable bottleneck, Could be wrong though.
Only thing you'd have to upgrade is the psu to accommodate a 3080, somewhere around 850 watts will be fine.
Ok thanks I already thought alittle about that
PCPartPicker Part List
CPU: Intel Core i5-12600KF 3.7 GHz 10-Core Processor  (2226.00kr @ Proshop)
CPU Cooler: ARCTIC Freezer i35 A-RGB CPU Cooler  (334.00kr @ Proshop)
Motherboard: MSI PRO B660-A DDR4 ATX LGA1700 Motherboard  (1301.00kr @ Proshop)
Storage: Western Digital Blue SN570 1 TB M.2-2280 NVME Solid State Drive  (775.19kr @ Senetic)
Video Card: Asus GeForce RTX 3070 Ti 8 GB TUF GAMING Video Card  (5790.00kr @ Proshop)
Case: NZXT H510 Flow ATX Mid Tower Case  (678.00kr @ Proshop)
Power Supply: Super Flower Leadex III Gold 850 W 80+ Gold Certified Fully Modular ATX Power Supply  (1002.00kr @ Proshop)
Case Fan: ARCTIC P12 56.3 CFM 120 mm Fan  (88.00kr @ Proshop)
Total: 12194.19kr
Generated by PCPartPicker 2022-07-25 10:37 CEST+0200
