Put together a new PC today. Inside of the CoolerMaster NR200P MAX.
Upon boot into BIOS they CPU is running crazy hot. No audible noise is being made from the pump block.
I tried unplugging/reseating the pump header and even moving it over to the other Fan header on the Mobo but nothing seems to work.
Any Ideas on things to try? Did I just get a dud pump block? Plz help troubleshoot this with me. Thanks for any advice & help!
Specs:
CoolerMaster NR200P Max
Intel 12700K
Asus ROG Strix b660-I
32GB Ram
3080TI
https://linustechtips.com/topic/1445300-coolermaster-aio-pump-header-not-working/
