Fan Placement Advice
Solved by Fasauceome,
2 minutes ago, evilpizzaman said:Under normal circumstances this is what I'd do, but I have a pretty substantial overclock going and have CPU temps averaging ~70 w/ peaks at almost 80 degrees under load, so I'd like to avoid this if possible.
If your thermals are satisfactory as it stands, the only thing I might recommend is two top intakes and a rear exhaust.
As always with airflow, experiment to make sure the changes you made are actually impacting you positively. The ambient conditions of your room specifically will be unique, and not every suggestion will perfectly take that into account.
