Can someone tell me the difference between these two UPS from APC. One cost significantly higher then the other. Should I go with the cheaper one?
APC Back-UPS 650VA, 120V, 8 NEMA outlets (4 surge) (https://www.se.com/ww/en/product/BE650G1-CN/apc-backups-650va-120v-8-nema-outlets-4-surge/)
VS
APC Easy UPS BV 650VA, 230V, AVR, 4 IEC outlets (https://www.se.com/ww/en/product/BV650-IN/apc-easy-ups-bv-650va-230v-avr-4-iec-outlets/)
First one is 94 bucks and 2nd one is 54 bucks.
https://linustechtips.com/topic/1445015-help-to-choose-ups/
aside from the voltage and outlet choice selections..
8 outlets <=> 4 outlets
390 watts <=> 360 watts
9Ah battery <=> 7Ah battery
make sure to select one with the correct voltage and outlets for your region.
https://linustechtips.com/topic/1445015-help-to-choose-ups/#findComment-15492794
VS
This is the manufacturer's website.  It would be better to link to the store where you're seeing these units and those prices.
https://linustechtips.com/topic/1445015-help-to-choose-ups/#findComment-15494032
