nopost No post in DOCP. Again..
Solved by XxBigRye,
3 hours ago, Guest 5150 said:RGB costs more.... but yes, try looking for this specific part number. F4-3200C14D-32GTZN
If you see a kit with the same part number but with a "C" at the end, that's the wrong kit and you'll have issues with it.
When you get this kit, and you still have troubles, tag me and I'll help you set it up.
I’m not concerned with price. I didn’t anticipate a set with a lower cas latency would be benificial. I thought the lower the latency the more chance of instability.
