How do I Raid 0 my 2 120GB SSD's with a M5A99FX Pro R2.0 MoBo?
Plug your SSD's SATA cables to the two middle (white) SATA ports on the motherboard, I'd put the HDD on the bottom outside white port, any Optical drive I'd stick in the Blue ports or the last White port.
Power on the computer and hit F2 to enter BIOS. In BIOS look for the SATA Controller settings and set it to RAID (RTFM for details), enable swap if the box is there. Exit BIOS, system will reboot, wait for the SATA RAID BIOS to pop up have your hands on the Control and I key ready and when you see the prompt press down on those keys, if you miss it just hit the reset button and try again. You will enter the RAID settings BIOS if you hit the Control and I key at the right time, set the RAID to RAID 0 and pick the two SSD's to be in the RAID group, do nothing to the HDD or any optical drives, just leave them as is.
Insert your OS install CD/DVD/Memory Stick and boot up and install OS, you may need to download the SATA RAID drivers for your mobo if the installer does not see the RAID array (should see a 240 or so sized disk which is the two SSD's in RAID 0).
Proceed as usual for the rest just make sure to install the RAID software so you can peek at the RAID array without having to go to BIOS.
Good luck and if you eff it up the first time you can try again and again till you get it right or get the hang of it so you end up becoming a RAID BOSS!
PS: Oh wait its an AMD board, maybe its not Control I but something else just watch the BIOS screen closely.
