Hello,
I bought this PC about 5 months ago, it was pre built. ( Respawn Ninja TOMAHAWK XS Gaming PC - RTX 3060 Ti - https://www.mwave.com.au/product/respawn-ninja-tomahawk-xs-gaming-pc-rtx-3060-ti-ac48534)
The CPU is an intel i9 9980HK, I have noticed the PC is getting very hot and have monitored the temperatures and they seem very high. When i start the PC they are fluctuating between 70 and 95 degrees celsius. Once everything has launched it then goes down to 60-70 but jumps up to 80-90.
I am now writing this post and while using chrome to do so my temps just got to 100 degrees and are currently sitting at 75, but is fluctuating upto 100
I have gone into BIOS and the temperature is normal there (50 degrees or so).
This is practically a brand new PC, and as far as I can tell there is no issue.
The only thing I would add is I haven't checked the temperatures up until this point in time as I assumed there would be nothing to worry about, so for all I know the temps could have been this high the entire time I had this PC.
I installed Windows 11 about a week ago, and I initially came to realisation about the temps on that OS and it was actually less severe (wasn't reaching 100degrees), I switched back to Windos 10 thinkings perhaps windows 11 was the reason for the temperatures and now it's worse.
I'd really appreciate any help
Thanks.
https://linustechtips.com/topic/1444100-cpu-temps-extremely-high/
12 hours ago, lemonAUS said:
Hello,
Thanks.
What an odd configuration. Must be a very weird mobo. I would contact the store as this is a prebuilt. 🙂
Gaming PC:
CPU: Ryzen 5800X3D | Motherboard: Gigabyte B550 Elite V2 | RAM: Crucial 2x16gb, 3200  JEDEC. | PSU: EVGA SuperNova 750 G3 | Monitor: LG 27GL850-B , Samsung C27HG70 |
GPU: Asus Prime RTX 5070ti OC| Sound: Odac + Fiio E09K | Case: Fractal Design R6 TG Blackout |Storage: Kingston Renegade 2TB and Corsair MP510 960gb | Cooling: CPU: Alphacool ST30 420mm rad, Alphacool CPU and GPU Core LT and Core blocks, D5 pump and res combo
Linux PC:
CPU: Ryzen 7700| Motherboard: Asus A620M-CSM | RAM: Crucial Pro 2x48gb, 5600  JEDEC. | PSU: Corsair CX750 | Monitor: LG 27GL850-B , Samsung C27HG70 |
GPU: MSI Gaming X RTX 3090 | Case: Lian Li Dan Cases A3-mATX black |Storage: SN7100 2TB + Samsung 860 EVO 512gb | Cooling: CPU: Thermalright Peerless Assassin Mini Fan(s): Noctua 1x NF-A14x25 Chromax
